EVGA XR1 實況擷取盒,擁有4K Pass-Through及4K/60FPS 遊玩時1080P/60FPS錄影功能,即時與世界分享您的最新戰況。XR1同時搭載了進階Pass Through模式,您僅需輕觸按鈕即可調整至144Hz FPS HDR。即刻甩開插拔線材的惡夢,XR1將成為簡潔高效的實況幫手。
為遊戲實況量身訂做
即時擷取並直播您大獲全勝的時刻:
商務人士的最佳夥伴
連接攝影機並以更畫質開使您至關重要的的視訊會議、講座及研討會。:
滿足重度直播一切需求
多組XR1及攝影機串接,實現多角度專業直播
自訂義ARGB LEDs
按下中央按鈕即可顯示音量、更換顏色。:
內建混音功能
不必再跳出遊戲調整,即可以中央按鈕控制您的麥克風輸入音量。
隨插即「玩」
連接 XR1 即可透過OBS™開始直播,無須另外安裝驅動程式。
EVGA XR1 RGB 軟體
EVGA XR1 Video
“Thanks to the EVGA XR1, I’m able to deliver high quality video with clear audio on my livestream. It allows me to go full HD with 60FPS playback.”
- DJ Z-Trip
https://www.twitch.tv/djztrip
“My DJ Stream on Twitch focuses on high end graphics effects with multiple camera angles, and the EVGA XR1 was able to deliver full HD with 60 frames per second!”
- DJ Buck Rodgers
https://www.twitch.tv/djbuckrodgers
“I have been using EVGA products for years and now with the new XR1 my live streams are looking better than ever, and installation was a snap.”
- Arabian Prince
“The EVGA XR1 Capture Device has secretly been in use on our weekly streams for weeks without hiccups. We are using multiple EVGA XR1’s to bring in multiple camera angles, PC’s and more. Delivering full 1080P 60FPS gaming and video, and being Certified for OBS allows quick and easy installation!”
- EVGA Weekly
https://www.evga.com/evgaweekly/
141-U1-CB10-LR
- Interface: USB 3.0 Type-C
- Video Input Interface: HDMI 2.0 (up to 4K@60fps)
- Audio Input Interface: HDMI
- Video Bypass: HDMI (up to 4K@60fps)
- Video Resolution Input: 480p / 576p / 720p / 1080p / 1440p / 2160p@60fps
- Video Resolution Pass Through: 480p / 576p / 720p / 1080p / 2160p@60fps
- Video Resolution Advanced Pass Through: 720p / 1080p / 1440p@120fps
- Encode Resolution: Up to 1080p @ 60fps
- Encode Format: RAW
- Dimension: 130mm x 86.4mm x 32.95mm w/ Control Dial /130mm x 86.4mm x 24.15mm w/o Control Dial
- Weight: 159g
- 1080p@60fps Video Capture
- 1440p@120fps HDR Advanced Pass Through
- 4K@60fps Pass Through
- Built in Audio Mixer via Control Dial
- Certified for OBS™
